Hi all )
I have just completed my first project recently, simple double acting, oscillating engine, had never got round to it due to setting up my garage conversion & making stuff to make stuff with over the past year, if you get my drift, anyhow it was made from drawings off the internet, hopefully the pics /vid will load up ok...
Initial machining of flywheel..
Some completed parts.. top & bottom cylinder covers, piston, conrod, main shaft, crank wheel, & marking out of frame..
Drilling inlet & exhaust ports, machining base flywheel pocket & frame & machining chamfers on cylinder block
Part assembly.. Finished assembly.. plus video of it running on approx 8 - 10 psi..
http://www.youtube.com/watch?v=_flCZHM3Utw
Hope all turns out ok.. onward & upward to my next project..
Regards
George (UK).
Regards
George (UK).
