Loaded questions.
First to answer "how big is too big", check out this link: http://www.shipsnostalgia.com/guides/William_Doxford_and_Sons#The_Manufactu
Tooling expenses are a never ending expense. Initially the expense will be rather high to obtain the following items:
[list type=decimal]
[li]Boring bars,[/li]
[li]HSS tool bits[/li]
[li]Bench grinder/belt grinder[/li]
[li]wrenches,[/li]
[li]chucks,[/li]
[li]QCTP - once you try it you many not go back to a rocker post,[/li]
[li]chip brush[/li]
[li]cutting oil,[/li]
[li]way oil,[/li]
[li]bearing oil,[/li]
[li]waste bucket - for the chips/strings you create,[/li]
[li]gloves - for use ONLY to clean out the chips after the lathe/mill is shut off,[/li]
[li]a whole lot of other stuff I can't think of right now[/li]
[/list]
[list type=decimal]
[li]wrenches,[/li]
[li]chucks,[/li]
[li]chip brush[/li]
[li]way oil,[/li]
[/list]
