[4]
Ford 4.6 Fuel Filter
[3]
[10] Like what you see?
racecar builder
Active Member
Dec 19, 2011
437
hot rodders
my sort of buddy a couple miles from me has above ground lift.
i can take fuel filter off and put new one on with real hose clamps right?
i have yet to get under car and look at it but
i've heard it's in a 'cage'.
plus Fram filter has 'single use' nylon tie type clamps.
i can just quick change it and then sort it out later on lift right?
Have A Nice Day!
Tony Wells
Platinum
Jan 22, 2011
7,069
Need year, make and body style to determine that, Bob. Some, if not most, use a quick release fitting rather than the standard old worm type hose clamp.
racecar builder
Active Member
Dec 19, 2011
437
tony
'99 lincoln towncar
point is i don't want to spend a lot of time under car.
i think cage will be held on by bolt into frame so
i'll just undo it.
then hook up new filter and take it down to lift.
Have A Nice Day!
Rbeckett
Silver
Rest In Peace
Sep 24, 2010
2,605
Fuel pressure has a tendency to blow off hoses thus the reason for the special fitting. Best to do it right and use the factory approved part and repair on this application. I have always beena firm believer in keeping things simple, but not this time.
Bob
racecar builder
Active Member
Dec 19, 2011
437
hot rodders
somebody has to explain to me how these little white nylon clips
hold the hose on better that steel hose clamps.
i have not seen this 'high fuel pressure' of fuel injection system in action.
i pressed on 'fuel pressure relief valve' and there wasn't any pressure!:)
i do get it that it's higher pressure than old mechanical fuel pump.
Have A Nice Day!
kd4gij
Feb 7, 2011
4,861
You can get a set of the release tools for a couple bucks. And they are much faster to change than worm clamps.
Took me all of 2 minutes to change the filter on my 99 F150. Make sure you relive the pressure be fore you disconnect it. Pressure can be as high as 50 psi
Oh and you probably won't need the plastic clips. I didn't.
kvt
Oct 21, 2014
2,082
A few of them have as much as 75 to 80 PSI. That plastic is just to keep it on as it clips behind a metal flange to keep it from blowing off, and believe me it can blow off if you do not get them on correctly. Ask me how I know. It is no fun laying on the side of the road in the middle of nowhere and in a puddle of gas trying to reconnect things. Wife sure was not happy, and when that happens no one is happy.
T
TOOLMASTER
Guest - Please Register!
I have found that the quickest way to get gas of of your clothing is to burn it....take them off first though.
kd4gij
Feb 7, 2011
4,861
That nylon clip if you need it does not hold the line on. It just prevents the release from getting depressed.
69thumper
Newbie
Nov 10, 2012
8
worm clamps will not work with the pressure that this system uses. the plastic clips are no big deal. you don't want to risk burning your car to the ground. just my advice, i'm an old ford mechanic.
FOMOGO
H-M Platinum Supporter ($50)
Sep 2, 2013
2,040
X3 - All the later injected stuff has one form or another of positive retention on all the fuel connections due to higher line pressure( 45psi or so). Ford is probably one of the easier ones to do yourself. The new direct injected systems are around 2200psi on the high side of the system. You should normally have pressure at the test port, but worn or leaking injectors can bleed off while sitting. Mike
[5] [7]
