- Sep 27, 2014
- 3,123
Hi all, I am having problems with the burner I made (Oliver downwind burner) I used a 1" Id sch 20 pipe at 9" long , the flame try's to burn inside the tube instead of out the flare , I drilled a #57 hole for the orfice?
You think opening up the hole would help I did use a 1" I'd pipe instead of 3/4" , I would like to keep it a Venturi system but forced air would prob fix it. I used a 7 gal air tank with two layers of insawool .
Any suggestions
Thanks
Derrick
Any suggestions
Thanks
Derrick
