[4]
Formable material used for measuring
[3]
[10] Like what you see?
Scra99tch
Active Member
Dec 2, 2016
44
I know they have clays and such for shaping around profiles and measuring. Does anyone know of a material that under a little bit of pressure can form around profiles?
I am trying to get an accuracte picture of a thread form while its in machine to make sure my grinding wheel has not lost its profile. So in my mind I would have a garlic press type lever that could push a sample of material into the threads while keeping a reference face parallel to the normal view of the thread. That way the material would not be fluid enough to ooze out of the rest of the thread channel, and if it did could be quickly ground, sliced off to give me something to measure.
Silly putty forms too well, JB-Weld would possibly work as long as I had a flat surface to reference on my grinder to clean up any "flashing", but would need to wait for it to set.
Thanks
Jim
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,668
I use a single edge razor blade to check the wheel profile. Just hold it up to the wheel, tipped slightly away from you, and grind the profile into the blade. Then you can look at the profile under whatever level of magnification you want, works great in a comparator.
Can't think of any quick way to do what you want.
francist
Sep 5, 2013
1,235
There is a silicone mold-making putty that I've used that would work admirably for this task. Two-part equal mix, consistency of silly putty but sets up within about two or three minutes. Detail is exquisite -- easily reproduces a fingerprint in great resolution. Only drawback is it's a bit pricey. Can't think of the name off-hand but I'll run down to the shop here and see if I have some. If not, I know I have some at home yet.
-frank
Edit: yup, had some downstairs. Trouble is no name on the containers! :rolleyes: Will check my stash at home at get back.
francist
Sep 5, 2013
1,235
Ok, here's a different brand but the same stuff. Look for it at craft stores or where you can get resin and supplies for mold making and casting.
-frank
David S
Nov 18, 2012
1,327
You could try polycaprolactone, trade names such as PolyMorph, InstaMorph, ThermoMorph. It is essentially a low melting temperature plastic used a lot in the hobby robots community.
David
BaronJ
Brass
Aug 7, 2018
660
Hi Guys,
There is always plastigauge. Mostly used for measuring clearances and the like. Its very similar to plasticine in nature and is reusable.
stupoty
Dec 2, 2012
1,181
Their was a youtube video from ox tools recently, where he copies some splines with a low temperature alloy, might be helpful.
Stu
bhigdog
Active Member
Apr 29, 2018
133
To check a formed wheel we used to hold a piece of 1/16" Phenolic fiber in a vice, run the wheel through it and check the profile. Didn't change the profile and I liked the smell...............Bob
Scra99tch
Active Member
Dec 2, 2016
44
Thanks great ideas. I'll be expermenting a little to find out our true thread forms.
[6]
[5] [7]
