[4]
Found a new source for flat belt material
[3]
[10] Like what you see?
Chris Hamel
H-M Supporter - Silver Member
Mar 8, 2015
66
Recently my belt needed replacing on my 9 inch sb. I have salvaged several treadmills for their motors and controllers. Kept the conveyor belts because they just seemed to good to throw out. At any rate, I cut a 1 1/8 inch strip and used it to make a belt. I laced the ends together with heavy nylon string. I put the rubberized side down. So far it is working good. Have to see how it holds up. The price was right.
lordbeezer
Sep 1, 2018
141
Should work out real good..the treadmill beIts are strong.bigger the treadmill the heavier the belt.. had a spliced serpentine belt on my 11" Sheldon for about 6 years.
SLK001
New Member
Mar 21, 2018
26
... I cut a 1 1/8 inch strip and used it to make a belt. I laced the ends together with heavy nylon string. I put the rubberized side down.
How did you cut the belt to width? Did you build a special tool to keep the same width (like a marking gauge with a blade)? Did you try to glue the ends instead of lacing?
john.k
Active Member
Nov 4, 2018
184
I have glued ends,and even with a very long scarf,and taking the cords into account ,the join eventually peels at the fine scarf,and fails,......Now I use whipper snipper cord,Stihl,is best...extremely tough and hard wearing.......I also use the polygroove auto belt,and lace it in the grooves ,which means no hit as the join goes over a pulley.Run with the groove side to pulley.
Chris Hamel
Mar 8, 2015
66
Actually it didn't work out so well. The lacing started to pull thru after about a month. Cutting it to width was a pain. I used a straight edge and a razor knife.
SLK001
New Member
Mar 21, 2018
26
Ahh, that's too bad... I've been wondering why I keep those old belts around, having not found a decent use for them. This would have been a very good reason for keeping.
FOMOGO
Sep 2, 2013
1,956
Nothing ventured nothing gained. I've used the treadmill belts for making way covers for my Bridgeport. Will be putting some on the new to me Gorton also. Another good use is protecting bench tops. Cheers, Mike
287448
Chris Hamel
Mar 8, 2015
66
I have found however they make excellent material to line tool box drawers.
SLK001
New Member
Mar 21, 2018
26
Well, they are glued at the factory to make the original joint, so there has to be some way to copy the same proceedure.
ELHEAD
Feb 13, 2014
272
How about a seat belt. I have had this mortiser at least 10years. It hasn't bee use a lot , maybe 3 hrs run time.
Markkjohnson
Newbie
Jul 4, 2017
7
I am now using a bailer belt spliced with the metal lace hooks. Now I can take a .030 cut with out any slipping. Now I only need the low speed to do any matching. Tandy leather makes a cutter that adjusts from ⅛ to 1 ½ inches in ⅛ steps, about $30.00
[6]
[5] [7]
