Four to three and a home made tap for plastic
malmac
Jun 7, 2016
361
I seem to have four and three all over again - but different this time.
We have a plastic water tank under the tray on our ute/truck. We are not happy with the location, filler inlet and breathers. So it is in the workshop getting a rejig.
We want to put a one inch pipe fitting into the plastic tank - so instead of buying an expensive tap - I decided to try and machine one up.
I couldn't find a lot on the internet about doing this - so had to wing some of it. If my mill had a nodding function I would have aimed for an undercut - but just went with a straight cut - which I am sure is not as effective.
More still to be done on this fix - but here is a stage one report - so get on with it team, I am sure you have a project that you have been going to start and just need some encouragement to make a small start.MAL_0163.jpgMAL_0164.jpgMAL_0168.jpgMAL_0169.jpgMAL_0171.jpg
Looks like it worked great . :encourage:
More still to be done on this fix - but here is a stage one report - so get on with it team, I am sure you have a project that you have been going to start and just need some encouragement to make a small start.View attachment 282516View attachment 282517View attachment 282518View attachment 282519View attachment 282520
I have made a few taps myself. You can achieve the same effect as nodding the head by offsetting the mill spindle axis from the RT axis.
neat! Another way to make a tap for a fitting into plastic is to get a spare threaded fitting (brass or steel, alu might work) and gash it with a Dremel. Works surprisingly well for a quick'n'dirty job.
I did try that with a steel pipe fitting but it was so off centre that it all ended up in the bin. You are right however with the right fitting it would certainly work I am sure.
I've been noticing (to my dismay) how badly off center and cockeyed the Chinese pipe fittings in big box and hardware stores have been, of late. I'd really be willing to pay a bit more for decent quality, but have been unable to find it. Grumbles!
Oh well we have purchased on price as a whole and we are reaping what we have sown. Our grandchildren won't even have a word for quality that makes any sense.
