Franko's Hf Engine Hoist Mod
I tacked on a small 3/8 socket to the jack and use a ratchet with a handle long enough to control the lowering.
Looks good, consider spraying a little paint inside the tubes or adding caps to the end of them.
Not a bad idea, Ed. I'd be concerned with ruining a seal welding on that stub. The plan is just a knob that I can use on both my shop press and the hoist. I saw a cool one that was made with a round faucet handle.
Hi
Are you going to do a Max test lift on it
Jeff, I don't have anything heavy enough to do a max lift test. I'm pretty confident with the welding, and each one is welded on all 4 sides. I put my weight on the hook and didn't see any movement or torquing to cause concern.
Ed, the schedule 40 tube is painted (or whatever that black coating is) on the inside. I sprayed in as far as it would go when I painted the cut ends.
Phase 2 is done (I hope). We'll see how the brass holds up.
I used an old chem lab faucet stem from my plumbing scraps. I cut off the washer part and trimmed down the water flow adjusting threads. Then, drilled a hole and milled some slots.
My jack valve wrench. Cost, $0. It took about an hour to make.
It seems to work well.
Thanks, Ed, John.
And, thanks to all who've looked, liked and commented.
I'm not sure what phase 3 will be. Probably some sort of organizer to keep my lifting straps and 800# ratcheting tie down that I use to balance the loads. Maybe a waterproof stuff sack and hanging hardware. And probably a stowage hook or ring for the pump valve wrench.
I have an idea for more compact long-term stowage, using a couple big hooks to hang the legs more compactly against the boom.
Nice work. Now I have something else to aspire to. Man You guys comeup with ideas I gotta do but don't have time to. Dang!
