- Feb 17, 2013
- 4,403
Here are a couple changes I made to my own engine hoist. The first is very simple - spray paint white around the holes in the arm, so they're easier to see and align with the "master" hole:I'm not sure what phase 3 will be.
Secondly, find a good, forged eyebolt and install it in the end of the arm opposite the chain. This is handy if you need just a skosh more height. I added a chunk of ¼" steel below the nut to spread the load a bit. Cross drill the end of the stud and add some kind of safety wire or clip, so it won't unscrew. Flip the arm as needed to use one or the other.
