- Feb 8, 2014
- 11,144
Just taking a break waiting for some tooling. Time to rant a bit and tell you how much I hate 304 SS.
I have been having fun making some parts out of 304SS. These start out as 3/4 inch round bar. The machine is my Hardinge CNC lathe.
The last batch of about 200 parts came out pretty good with minimal problems, but this batch has been a PITA. The material is harder this run and has been eating tools and tool holders, including two $150 parting insert holders. The second one lasted about 5 parts.
http://www.iscar.com/eCatalog/Family.aspx?fnum=387&mapp=TG&GFSTYP=M
I have now made major modifications to the tool path cutting strategy and feeds & speeds to solve the parting tool issues. Rather than side loading the parting tool as I had been, taking a light finish cut (which had been working fine), I'm using a ''V'' shaped tool to do all but the deep grooving. A parting tool can be used for finish turning, but not in this stuff.
But now with the ''V'' cutter I'm getting about 3 parts out of each edge of some cheap (about $4 each) carbide inserts, I have some good ones designed for SS ($17 each) on order and they should be here this afternoon sometime. I'm down to 120 FPM when I should be running at about 300 FPM and still eating tools. I can't really complain about the cheap inserts, they are not designed to cut SS, and they got me through enough parts to get by for the moment.
All operations are done in the lathe including the slot and lead in chamfer on the end. This is the way they come out of the lathe, from here they go into vibratory deburr and are done.
Oh, then there was the tool change (attempt) without moving the carriage to a safe position and CRASH, there goes a $125 carbide thread mill. That's what happens when you forget to tell the carriage to move to a safe tool change location, G53 is your friend. I now have a a few new lines of code in my software that will hopefully prevent me from doing something stupid like that again. Sometimes you need to make the software smarter than you are
http://internaltool.com/products/mill/34/thread-mills 1/2 shank, 3/4 inch cutter dia. I use this for cutting a 1''-8 internal thread in 6061, about 2'' deep, in one pass.
OK, end of rant, time to go back to work.
