[4]
Funny Fluted Drill Bit
[3]
[10] Like what you see?
azshadeguy
Active Member
Jul 16, 2017
69
Likes
31
#1
I hope the pictures come out so you can see the flutes. IMG_2051.JPG IMG_2051.JPG IMG_2050.JPG IMG_2049.JPG
Is this a special drill bit or a fluke? IMG_2049.JPG IMG_2050.JPG It looks like it's bent but it is straight.
The only markings are /64
T Bredehoft
Dec 27, 2014
2,793
Likes
2,135
#2
That had to be made on purpose, I wonder what the purpose was...
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#3
I've seen similar drills. My guess is that they are improperly heat treated and get twisted while in a bind. At the cutting end, it appears to have a LH twist, but other parts have a RH twist. And there is the sort of no-twist area of transition. I can't think of a valid reason to make a drill with that configuration intentionally.
Cadillac
Brass
Mar 12, 2018
587
Likes
612
#4
It looks like it’s twist was unraveled. If you roll it it’s straight? In the fifth or sixth picture it sure looks like it’s got a droop.
Cadillac
Brass
Mar 12, 2018
587
Likes
612
#5
You beat me to it Tony.
Tony Wells
Platinum
Jan 22, 2011
7,052
Likes
2,135
#6
Not by much, Caddy. ;)
BtoVin83
Active Member
Aug 30, 2017
190
Likes
182
#7
i have seen that happen, telephone installer drilling a hole through the wall. Drill bit wound up with insulation and the drill motor unwound the bit. Staid pretty straight too.
FLguy
Jan 11, 2016
256
Likes
140
#8
Drill bit to drill Maple trees for sap?
azshadeguy
Active Member
Jul 16, 2017
69
Likes
31
#9
It rolls across the table pretty smooth
Holescreek
Nov 10, 2013
759
Likes
666
#10
I have one similar somewhere in the shop. I haven't seen it in a few years.
Superburban
Jan 2, 2016
630
Likes
456
#12
Simple, its for a reciprocating drill. :):)
There is router bits like that for wood. So both sides of the bit cut each side of the wood inwards, so there is little splintering of the edge. Called a compression bit.
Scruffy
Jun 5, 2013
484
Likes
284
#13
Really ,never seen or heard of such of a bit like that.
Ron in ohio
ELHEAD
Feb 13, 2014
259
Likes
201
#14
Looks identical to a couple of H F brand bits after first use.
Dave
killswitch505
Nov 10, 2013
322
Likes
315
#15
I’m going with it’s a shaft from a yankie screwdriver that someone fashioned into prison shank but I have a really active imagination
Dredb
Active Member
Jan 6, 2018
94
Likes
90
#16
It's a rubbish drill bit, they used to be sold in supermarkets over here, you could bend them with your bare hands.
brino
Jan 2, 2014
3,461
Likes
3,487
#17
@Superburban Thanks!
I had never seen those up-cut/down-cut router bits before, you taught me something new.
Here's a couple references:
What the heck is a compression router bit?
Compression Spiral and Spiral Solid Carbide Router Bits
Apparently often used for CNC routers in MDF and plywood to reduce splintering and tear-out on BOTH faces.
Although they do not look like the pictures from the start of this thread.......those just look like poorly made drill bits that got jammed and then "rearranged" themselves.....
-brino
RJSakowski
Feb 1, 2015
3,684
Likes
4,288
#18
Soft steel. I have had cheap drill bits intended for drilling wood unwind in the past. A properly tempered HSS bit will break before it unwinds.
whitmore
Active Member
Mar 3, 2017
354
Likes
198
#19
I think it's a Rotazip bit, intended for drilling into sheetrock (gypsum board) and then acts as a rotary file for sideways cuts.
Goes kinda fast, and it's too floppy for more robust materials. Makes good rectangle holes for outlets, though, quickly.
Superburban
Jan 2, 2016
630
Likes
456
#20
-brino
Yea, I knew they did not look the same. But on closer look, it is interesting that the original has the flutes change direction twice. The first change has both cutting edges cutting outward, which generally will create more splintering. Also does not look strong enough to cut anything more then Styrofoam, without breaking.
Even if you got it red hot, I think It would take some careful work to get the twisting, without the outer web of the flute cracking.
I wonder if it is one of those things a machinist does when he has spare time, and an inquiring mind. Or even something created by a drill maker, as a novelty.
[6]
[5] [7]
