- Apr 7, 2011
- 15
The lathe I just bought had a Furnas reversing drum switch that I hooked power up to today!It run the motor in forward rotation. It would not reverse the motor. The power to the switch is 2 conductor with a ground.From the switch to the motor is also 2 conductor w/a ground. The motor is 220v and has 4 wires in the junction box.
Inside of the switch are 4 contact points.Two on the in side and 2 on the out side of the switch.Am I missing a pair of contacts?
