G0704 Yaxis Moving (wiggling) While Transversing The X Axis
sierrasmith71
Aug 2, 2016
12
While I was indicating my vice on my new Grizzly G0704 mill, I notice that while I was moving the table in the X axis the test indicator showed a Y axis shift of 1/2 a thou to a full thou per revolution of the lead screw?
Is this to be expected? or do I need to adjust something?
Thanks from a noob!
David G.
Gaithersburg MD
If it is that new, you may want to tighten the GIB screws up a little.
Tighten enough to still let it move freely without binding.
Mine were loose like that also. Just tightened them up and all was good.
I just remembered that I had not tighten the Y axis locks; securing them helped a bit. I will play with the X axis gibs and see what effect that has.
Thanks
David G.
