[4]
G4003G stand question
[3]
[10] Like what you see?
MKeen
Newbie
Jun 13, 2018
5
Just received my G4003G lathe and have a simple stand question. I noticed that inside the doors the floor of the stand has a 1 inch gap which allows stuff to fall through. (Like small change gears..ask me how I know). Besides probing around using a magnetic pickup is there an easy way to retrieve anything that slipped through the floor?
Tozguy
Feb 15, 2013
1,793
Would anything falling through the gap just land on the floor? When something rolls under my lathe cabinets I fish it out with a stick.
MKeen
Newbie
Jun 13, 2018
5
Normally yes, but in the case of these stands there is no gap. Bottom of the stand is one piece solid plate with 4 3/4" holes for mounting
Tozguy
Feb 15, 2013
1,793
Then the part is sitting on the solid plate bottom?
dlane
Sep 27, 2014
3,045
Duck /gorilla tape the holes shut
MKeen
Newbie
Jun 13, 2018
5
Yes I believe the part is sitting on top of the stands bottom plate. I will most use a magnetic probe to retrieve it. Then duct tape it closed.
Mitch Alsup
Active Member
Nov 17, 2017
372
The cabinets that came on my G4003G lathe have no way for stuff on the inside to get to the outside except through the open door.
I put my cabinets on on machine feet and adjusted each so it holds equal torque while the level indicates lathe is level.
jocat54
Dec 25, 2011
526
Cut a piece of plywood to fit on the shelf snug--no gaps.
Yeah I know wood on a metal lathe:)
MKeen
Newbie
Jun 13, 2018
5
Looking at this further. It seems the stand under the headstock only has about 1/2" gap really to small for anything to fall in. however the stand at the tail end someone goofed there is almost a 2" gap, something to consider when storing tolls there. On a good note finally got the lathe leveled. I have about .00015 taper per 12".
Superburban
Jan 2, 2016
654
The cabinets have changed at least once over the years. I have seen some that are cast iron, and others that are welded steel.
[6]
[5] [7]
