Garden Tiller Retrofit
petcnc
Dec 29, 2012
323
Note: Some parts of this were published some time ago in "what-did-you-do-in-your-shop-today". Here is the full story
I inherited an FMC Bolens 2230 Walk behind tiller model 1978!
295504
It was an honest and reliable little horse but, as most things in this life (I do not have any info for the other life) it got old. As a result a few of its parts (engine, chain, axle, bearings, oil seals & blades) needed replacement.
295505
First thing that got retired was the B&S 3HP engine. I replaced it with a ChinMade 6.5HP.
295506
For a couple of years it worked like new. Then the tine blades and the axle supporting the blades showed signs of ageing. Everywhere there were signs of deterioration!
295507
295508
As the gear lube was leaking I decided to dismantle it and inspect the gear box.
295509
The shaft was in a bad shape the oil seals did not hold the gear lube and the bearings allowed too much play.
295510
Measurements of the different parts gave the following data:
295511
Instead of 31,75mm (1 1/4") diameter The shaft was 31.25 on the right side and 31.40mm on the left. This allowed excessive play and oil leak.
The chain driving the main shaft had too much wear
It was time for a new shaft, new bearings, new oil seals and new chains to make a proper repair of the gearbox.
Shaft, chains and oil seals were no problem to find locally. A 32mm steel rod for 5$ took its place on my lathe to be transformed.
295512
The bearings though had to be special order from Germany and took a week to arrive.
295513
Some minor cleaning of the bearing seats needed as the reinforcing weld (done in the past) deformed the seats slightly.
295514
After reducing the shaft diameter from 32mm to 31.75 (with the help of sand paper to achieve precision) I had to remove the sprocket from the old rod and transfer it to the new.
295515
I removed the old welding on my mini lathe
295516
295517
Then it needed a press (that I do not own yet)! A 20 ton bottle jack did the job in seconds
295518
Old & new side by side
295519
Some welding and the new shaft was ready.
295520
Final thing was to assembly the gearbox again (notice the primitive chain tension mechanism!!).
295521
A new gasket was added as well and job done.
295522
New blades replaced the old worn blades
295523
After some paint, roto tiller fully assembled and functional again.
295524
Notice the antivibration engine mounts. That was a huge relief for operator’s (i.e. my) hands!
295525
Thanks for reading
Petros
NortonDommi
Nov 15, 2016
585
Just have to say that is not old. I've just,(yesterday),replace a broken circlip on the worm shaft of my 1960 Masport Rota Hoe powered by a Clinton Red Horse 6.3 HP engine. It had been sitting for a couple of years as the main jet had pulled the thread,(it holds the float bowl on as well),plus it had a worn throttle shaft and I had been a bit slack on getting around to repiring it.
I made a new throttle shaft, built up the damage threads with Belzona and made a new drive engagement lever/shaft as the old parted in two from rust. Started first pull and did a good 3 hours work tilling the neighbors lawn.
P.S. I'm the second owner. I bought it from a semi-retired market gardener who at 73 bought a ride-on after 39 years of use, that was 20 years ago.
I'd like to see a modern machine match that.
Superburban
H-M Supporter - Gold Member
Jan 2, 2016
1,112
Great job, and write up. I'm amazed that chain tensioner is not all worn out.
petcnc
Dec 29, 2012
323
Nice Job !
I salute you for taking what many would throw away and bringing it back to usefulness. :applause:
Well... I needed a tiller for my garden so I looked around for a new one. New tillers, compared to the old one, will not last more than a few seasons! Everything is so fragile today!!!!
So repairing it was the wiser move. Besides the joy of resurecting it!!!
I was amazed as well but as I investigated it a) It works submerged in oil and b) the chain just touches it so there are no real pressure applied to it
