- Feb 28, 2019
- 499
Cool. I've also done some free hand turning of metal (I was originally a wood turner).This was done free hand on my Logan.
So similar idea but flat work.
You are not missing anything.Maybe I am missing something. Isn't this just what a CNC machine does from a CAD file?
Bridgeport made a mill that had a head that could move to follow a pre-made pattern. Is that what you mean?
Edit: called the true trace
If I'm understanding this correctly, you want something that is more precise than just getting it close with various cutters then using a file to clean it up so it's smooth, correct?I have on more than one occasion wanted to machine a complex 2d curve profile. The most general case is a curve that has both convex and concave components. But either concave or convex non-circular curves also apply.
These are the kinds of things you would do with a pin router or following a template with a router if you were working with wood.
I have done convex curves with lots of straight cuts to approximate the curve. This works but is slow and time consuming, perhaps there is a better way?
For convex curves, I can imagine using a boring head or fly cutter and determining a number of circular cuts that would approximate the internal curve.
In both cases the result is something that will still need some hand work to smooth out or something that is approximate depending on how accurate you need to match a given curve and much fussing you are willing to do to get there.
One could also just make a long list of points to hit in order and do a painfully slow manual CNC job. I imagine that there are / were specialized machines that could do this prior to everything being CNC.
My question is: is there a general solution to this kind of task that's (relatively) efficient or some affordable or relatively easy to make shop fixture that can accomplish this?
Keith Fenner did a You Tube video of turning a 2" ball on the end of a shaft using a stylus to trace a pattern. While he was making a simple ball, the attachment could be used to make any desired shape.I’m not sure which of these best applies: “great minds think alike”, or “enquiring minds want to know”.
But, I’ve been sitting on a similar egg for a few months now but for one of my lathes and not a milling machine.
Essentially I want a faster and more repeatable way to turn a fairly gentle curve on a piece (actually a series of half a dozen pieces, maybe). The best I can come up with so far is a template in the back that would afford the desired shape for a stylus to follow. Said stylus would be attached to the back of my lathe cross slide, so as I advance the cross slide in to take the next cut it would only go as far as the template allowed, thereby creating a loose reference frame for achieving the rough curve shape.
Yes there would still be a lot of hands-on feel to get the thing to work and of course still a lot of traversing as I nibble down to the final shape, but it should limit the risk of overshooting the curve and hopefully take some of the uncertainty of how much to advance at a time.
Alas no drawings other than my typical thumbnail sketch that I knock together on a coffee break, but it’s good enough to get the idea down. Maybe you’ll see where I’m going with it? At any rate, I haven’t had a chance to put it into practise yet, I need to dig out from under some other things first, but it’s still on the list to see if it’ll work. The lathe will be either my 618 in the shop or the Craftsman equivalent upstairs, both of which have flat ways which lend themselves to fitting things fairly easily.
-frank
