Getting Started With A Lathe
Brian, good job on sprucing up the lathe. Its a looker now.
Hope you enjoy running it. Please let us know how it goes.
Thanks Tozguy! It was a fun project, people that saw it before thought it was silly to even bother with it. I have some learning to do all in all, I am not totally in the dark about lathes as I have used them in shops I have worked in, but it was just trial and error as no one else seemed to know what they were doing either!
Welcome to the best hobby machinist forum in the world. Very nice restoration on your 109.
The 12L14 is perfect for learning the machine. It machines easily with a nice finish and helps to learn about the grinding of tools. Small changes make a big difference in the finish. It polishes up bright and shiny on a buffer. Just not good for welding due to the lead content. When the guys and gals here told me about it I ordered some from onlinemetals and have to say it is my favorite metal to machine. Acetal delrin is also easy to machine and the finish very sensitive to tool angles. I really like working with it. My little 7x16 minilathe loves these two materials.
Roy
Nice!...All the above suggestions for stock are good (mild steels, aluminum and plastics)....but believe it or not, with the proper speeds and feeds (and smaller cuts)....and proper cutter (tool) angles, and maybe some elbow grease keeping the cross slide and/or compound from sucking in (if needed), yoose' can even cut prehard toolsteels....Cheers and have fun!
Harden steel actually cuts really pretty & is probably easier to get to a spot on target. But... It can also be a pain until you learn what speed to run it at. I've burnt a few pieces of carbide up in unknown metal.
Rust is much harder then the metal so try to get below it when you take the first cut when you can. I usually try to take that first cut with a junk cutter to remove rust then switch to something sharp to finish.
Hello all, new here, I have craftsman 109 that I have restored and I am well aware of the limitations of these machines. It is mechanically sound, I feel it is close/good tolerances for for this type of machine. My question is what type of material should I use to make some "practice" cuts to further dial this thing in along with my bit grinding skills. I have been using some cold rolled w/ hss bits but I think my end results could be better. I know these are not the best machines and I would upgrade once I find something, but in the meantime its all I got to learn the lathe a bit better, thanks!
A good source of highly finished mild steel for turning practice is the brightly finished rod in automotive shock absorbers and nitrogen filled lift cylinders used for hood supports and rear deck lids on SUV's. All should be free for the asking at any auto repair shop.
Interesting, I wonder if pneumatic cylinders would use the same type of steel for the shaft. Some of these shafts can be over 1" diameter. I change these out regularly at my work and they are just getting tossed in the garbage.
Whatever materials you choose, that is still a pretty small lathe. The key will be to stick with HSS tooling and get really familiar with tool geometry. As Roy(esses) said, small changes make a big difference ...
Take one home and see. I would bet $100 of my wife's money that the pneumatic cylinder shafts are micro finished mild steel.
I will need to look closer at these shafts if nothing else a way to collect some material for future projects. I may be wrong but I had thought some of these types of shafts/pistons had a chrome plating.
