- Sep 24, 2020
- 1,906
Looks like some heavy wear in front of the tailstock, also.It looks like the worst of it extends to the inside edge of the chuck and then stops. The carriage might not go this far while using the 3 jaw chuck, but when you remove it to use a collet or face plate you will be going much farther towards the spindle. So, yes, I would say that machine has been heavily used up by the spindle, lack of lubrication, or both. But, depending on what type of work you want to do with it and the price you can get if for it might still be worth checking out.
Ted
