Maybe, if 2 things were different, maybe 3. That's way too much stick out for that brazed carbide tool bit. If it were shorter, then maybe but maybe not.
Chances are the tool heights for those 2 tools aren't the same. I'm assuming you are using the carbide tool bit for chamferring. If yes then having that tool exactly on centerline if not critical but it should be some what close to the same cutting height as the indexable tool. You could always shim it too.
Having a second tool bit might arguably be a safety hazard. I don't mind it as long as it's not sticking out like in the pic. Some tool posts setups have 2-4 tool bits mounted in them anyway.
I have the same style brazed carbide tool bits used for chamferring. I have 2 mounted in 2 different holders that are setup for both orientations on my QCTP. They're the same exact size so I've been meaning to just mount them in 1 tool holder back to back also. But I have plenty of tool holders still so I don't care.
Lots of maybes that I said in this post, so I say maybe, I don't oppose it, except for that stick out.
