- Jan 6, 2017
- 1,214
This was something I've wanted to do for a long time. 6000$ worth of 4ftx8ft x 1/4" steel plates, 2"x4"x1/4" rectangular tubing, wheels, tires, axles, springs, nuts, bolts and various other widgets. It took a month to design in CAD and fabricate.
No propane or water heater tanks. All 1/4" plate steel with triangular facets for the end cap.
The door is 200lbs, and the counterweight is 185lbs. The linkage geometry allows the door a vertical component weight advantage in the down position, and the counterweight the vertical component advantage when the door is up. The result is that the door stays down, and up, on its own with no props or springs. And can be lifted with about 10lbs of force. The 200lb door can be lifted with 2 fingers.
Overall, it came it at 2998 lbs and is 15' long x 5' wide. Registered and road legal.
It cooks a damn good brisket!
It's a reverse flow design:
Comes with security. In exchange for a few healthy portions of brisket and pulled pork.
