I recently bought a new Grizzly G0602 lathe 10x22. I thought it was pretty decent, but having a problem with it. In Grizzly's nomenclatures it states it can use 1/2 inch tool bits. Here's where my problem begins. A 1/2 inch tool bit, when you line it up with a center in the chuck or tail stock, is 1/8th inch above center. Let me back up and tell you that this lathe has the turret style tool post that is square. A 3/8 inch tool bit is 1/32 inch off center. A 5/16 inch tool bit is dead on. I informed Grizzly's tech service about this and I got the run around for about a month. The first tech said he would mill off the amount needed from the bottom of the tool rest. Another tech said no don't do that as it is wrong. The last tech said that they have verified problems with the wrong parts put on the lathe. He had me measure the thickness of the bottom of the tool rest and also the thickness of the compression ring which clamps the degree wheel down underneath the compound slide. He gave me the measures and I found that the compression ring was dead on. The bottom of the tool rest was only .006 inch off. I reported those back to him and he said their top man would be giving me a phone call. I never got it. This past Monday I called and got yet another tech and he reviewed my ticket and said Grizzly apologizes and told me that the lathe is suppose to use a 5/16 inch tool bit. I told him for the size of that lathe, particularly the size of the tool rest, that a 5/16 inch bit is a mini lathe tool bit. The large tool rest screws barely clamps a bit that size with two screws and there are three in the rest. I said the same turret tool post on my mini lathe is half the size of the G0602. He said I could grind the bits to fit. They said they can be of no further assistance. Am I missing something? Am I wrong about this? Anyone else have problems with Grizzly's service department? What would you gentle do or recommend?
