- Aug 2, 2016
- 12
While investigating how to install a Sino DRO glass slide for the X axis on the table front edge, I took off the Y axis hand wheel to see if I could get a little more clearance for the read head when the Y axis was moved fully forward.
No luck there, so I installed the hand wheel and found that the tightness of the acorn nut really effects the amount to backlash of the hand wheel. Then I remembered that I read some where ( good ole Internet) that the hand wheel acorn nut not only holds the wheel on, it also provides a preload to the lead screw thrust bearings.
So my question is how tight is too much or how loose is too loose?
BTW I decided to mount the slide horizontally instead of vertically. Sino approves of this mounting scheme and it solves the read head clearance problem for me.
David G.
Gaithersburg MD
David G.
Gaithersburg MD
