[4]
Grizzly G0752 carriage question
[3]
[10] Like what you see?
WarrenP
Active Member
Feb 25, 2018
152
Hey Everyone, I have another question about the G0752. I was wondering what part of the bed/ways does the carriage actually slide on. On both ways there are a flat section, then there is the upside down V shaped section. I couldn't tell just by looking and I didn't want to take the apron apart just to make sure of what I thought. I thought the apron ran back and forth on top of the flat section so I always leveled the lathe according to the flat part. I noticed that the V part isn't level the same as the flat so I am hoping I am right in using the flat part with a couple 123 blocks to higher the level to level the lathe. Im sure a dumb question but with me replacing the spindle bearings and need to check the headstock alignment, etc I was leveling the ways and wanted to make sure I wasn't wrong . Thanks for any help on this. Warren
cathead
CATWERKS LTD
Feb 7, 2013
1,061
Generally both the carriage and tail stock run on one flat way and one vee way. It's easy to see the tailstock ways so the
other two are for the carriage. The vee keeps the tail stock and carriage perfectly parallel to the ways.
The_Apprentice
H-M Supporter - Gold Member
Staff member
Jun 14, 2017
248
You should be able to tell by just observing how the oil streaks. You HAVE been putting oil on the ways, yes? :)
While i do not have a Grizzly (yet), I have examined my King. Of the two flat way sections, the one with the 'V' is not even touched. In fact, if you look under the carriage, none of the flat on that side is even touched. The 'V' carries the whole weight.
On the other side, there is a chunk of the flat being used, but at least 1/3 of it seems to have no contact ever with anything.
Ohh, and my ways I have are both Hardened & Ground if that solves any further questions.
Now, hopefully someone with your model can give you better input here.
Dave Paine
Brass
May 10, 2014
813
Looking at the Grizzly site pictures, the carriage has wipers for the front "V" so it will ride on this "V" and the rear flat section. The tailstock appears to ride on the two flat sections.
This lathe seems to only have a single "V".
jwmelvin
Active Member
Jan 11, 2018
151
I have a G0602. Carriage rides on the outer rails, front is V and rear is flat. Tailstock rides on inner rails, front is flat and rear is V.
That said, my understanding is to level it using 123 blocks on the flat sections.
Mitch Alsup
Active Member
Nov 17, 2017
418
On my G4003G, the carriage slides on the V in front and the flat on the back,
while the tailstock glides on the flat in front and the v on the back.
WarrenP
Active Member
Feb 25, 2018
152
OK, that answers my question about leveling, I will still use the flat sections with 123 blocks. Good to know I was doing it correctly. Just wanted to confirm. Thank You.
[6]
[5] [7]
