- Nov 24, 2014
- 3,156
My suggestion was to incorporate "some blind holes for a pin".
The nut doesn't have to be tight, like a draw nut for a 5C does.
It just sets and maintains the axial clearance or the spindle which will not require to be "tightened".
The blind holes/pin are really for some worst case scenario.
I expect that all will have (or can make) an appropriate pin (or rod, or punch).
No uncommon tools required.
Also, regarding the brass ball vs a brass tipped setscrew.
On the commercial brass tipped screws that I have seen/used, the tips are fixed (press fit or bonded) to the screw shank.
That type is not desirable for locking a thread because the rotation of the locking screw will rotate the brass element.
You don't want the brass element to rotate (wear away, create debris). You want the brass element to be non-rotating.
I recommended a brass ball because they are inexpensive and available in multiple sizes from McMaster-Carr.
The force of the setscrew will deform the ball, creating a thread-like form to bear on the spindle thread without damage.
Make sure the locking screw tip (setscrew in this case) has a relatively smooth tip to bear on the brass element.
Certainly, the brass ball could be replaced by an appropriate slug of brass rod.
