- Apr 29, 2019
- 2,058
OK, I'm better now.
Was a close call.
Let a lot of the magic blue smoke out from between my ears.
I looked at what it would take to add the dual support to the worm shaft. One change affects another and it is a cascading effect, It would be a pretty major redesign to add it at this point and might even eliminate some other features. Unless a majority of us would really like it, I would say we should pass on that one. The shaft as designed is pretty hefty and I think that even if you added a stepper or servo drive for spiral cuts down the road I think it would still be fine.
As for the double custom made jam nuts with 2 inh hex on the bottom of the spindle, That would be a simple change to make it something like a round nut that is knurled and locked by set screws, then no one has to come up with a special wrench or spanner to tighten it. You really will not want it any more than a light finger tight. Just enough to eliminate end play of the spindle.
Whether it is the nuts or a round, it is still parts (2 nuts or 1 round) someone has to make.
Let me know your thoughts.
Was a close call.
