So I'm playing with that design like TomMakeHere did in the design we talked about above. I was trying to modify it slightly to use imperial bearings (not particularly possible with the front needle bearing), but I'm also not a fan of how the body needs to be formed in order to use 2 bearings. There is a double-flat internal dimension where the distance between the two flats its pretty critical. It seems to me that it would be a pretty nasty dimension to hit, particularly in the sizes we're talking about.
Instead, I have 2 options:
1- I go with a longer needle bearing at the front, and count on THAT to control the 'sheering', then just the thrust bearing at the back. It is perhaps a little suceptible to radial forces as the 'back' is unsupported in that way (though ~1" of support at the front).
2- Do those (perhaps the 3/4 needle bearing still at the front), but replace the thurst bearing/normal bearing with a taper-roller bearing. GunsOfNavarone posted above about a 1/2" one that would work fine, if a little large, resulting in a slightly larger diameter body.
I could optimally use a 3/8" ID taper roller bearing, but I couldn't find any cheap ones.
Additionally, I'd like to add 2 features, which I think I'd like to hear feedback from the builders/others!
1- Some sort of grease nipple. TomMakesHere's version (the fluted one in the video above) looks like it requires ocassional disassembly to grease the needle bearing and thrust bearing. He has to do this because his normal bearing on the back ends up being sealed. Even in his design I think I could put a grease nipple on the body.
2- calibration screws: Once you've got it assembled, you have to get the offset on the 1 degree taper right-on to make sure the 'points' of your bit are all the same 'height'. The one in the original-post uses a couple of adjustment screws to do so, TomMakesHere suggests just 'tapping' it in after loosening the bolts. I'd love to do the adjustment screws if I could find a place for them.
So, thoughts/feedback? Anyone have a 3/8" ID taper roller bearing I could design this around?
