- Oct 14, 2014
- 1,969
I bought this VFD from automation direct
https://www.automationdirect.com/ad...l)/GS1_Drive_Units_(120_-z-_230_VAC)/GS1-10P2
I want to use it to run a fan. When power is applied, fan runs. That's it. Pot on VFD will set speed.
With below settings, the fan will not start with a jumper between CM and D11. If the VFD is powered up, then CM and D11 is jumpered later the fan runs. In other words it needs a delay on to work correctly. (Manual states CM to D11 will cause run forward with correct params)
OK, I set the params to remote control. Tried both 3-00 set to 1 and 2
tried both 3-01 set to 0 and 1.
There must be a way to program this unit to just run when power is applied.
Suggestions?
Suggestions?
