- Jul 5, 2014
- 2,759
Yesterday morning I was running my lathe trying to get a multi start thread worked out. I broke a $43 insert so back to the drawing board to try and reprogram in to fix that.
I played with it and went back out to the shop and turned the RPC on and got the loud buzzng sound that makes you sick to your stomach thinking what happened? Worked fine this morning.
So out came the multi meter checking voltages, connections, the motor and all I had was power on L1 and L2 (the 220v through lines from my shop) but nothing on L3.
Also emailed Jim Dawson about a contactor that I thought was the problem. It's discontinued so wanted to replace it with one that would handle more amps.
I called the guy that I bought the panel from and he said to take the contacter apart and clean the contacts and then I found this.
Apparently the wires were shoved in too far and they were tightened down on the insulation and not the bare wire. And they were in so far that they kept the contactor from seating and were only making contact on the very end of the wire.
Told the guy about it and he said that's not supposed to happen. Well no sh*t.
So now I'm back up and running.
Ok, rant over. I'm better now..............well mostly................maybe not.
