- Feb 2, 2017
- 1,234
I finally got around to getting a Starrett blade onto my new HF 4x6 band saw. I got the guides set up and the top wheel adjusted so the blade tracks fairly well.
I've downloaded the 4x6 set up guide from Yahoo Groups, but haven't gotten a chance to walk through it yet. I think my saw is usable as-is, but is no where near where I want it to be (using my Jet 14" steel woodworking band saw as a benchmark).
The first question I have is whether it's ok for the blade to only be halfway on the bottom (driven) wheel? The blade seems to run correctly on the top wheel, with the teeth just hanging over the edge, but the blade only has ~1/4" - 3/8" on the bottom wheel. I suspect that means I need to shim the bottom wheel over 1/4"? If so, that seems like an awful lot of misalignment?
Here's the top wheel for comparison:
The second question is that the gear box seems to make an awful lot of noise. I've seen some people's reports that the gears need filing, so I opened up the gear box, but the gears actually seem to mesh pretty well, and I didn't see/feel any rough spots. What suggestions do you have?
Thanks,
Evan
Thanks,
Evan
