After reading many comments on this and other forums I decided to get an 8 x 14. I have made a few parts but I put most of my time getting it set up. I did take much of it apart and clean it up and stone the gibs but i do not think it needed to be done. the r & r did give me more familiarity with the tool. I have not use a lathe in many years so it is new to me but it has been a better than expected experience.
One of the biggest parts of buying this tool is that I want to do ever mod that everyone has done and then some. I finally settled on getting it to a point I can use it for my needs of making simple parts out of .
What I made
Thank you to everyone that has been contributing to these forums you have been so helpful in so many ways
ps. That is a tail stock v block i am working on now
What I made
- Bench - legs were laying around. Made the top out of 2x6s sandwiched between plywood on top and bottom. drawers are all 3/4 plywood and I used 2 sets of 100# full runners on the large drawers 200# capacity
- Coolant system - bought a mag base and the flexible nozzles (the expensive part) used a 5 gal bucket an old marine bilge pump and a small transformer that was laying around (like a toy or electronic charger) I through in a small piece of oil boom to soak up any stray oil. I screwed the pump to check of steel to keep it aft the bottom and to make sure it sat in place
- drip pan and back splash - friend gave me a sheet or stainless and i bowered a heavy duty break. it took quite a bit of planning to make the back splash. the lath is bolted down 1/8" out of level so that I need to adjust the table to level the lathe this helped with the coolant running to the tray drain.
- Lexan shield.- It was already cut the right length i just notched it out to make it a little easier to get close to the chuck. The shield comes in hand when coolant gets on large diameter parts
- DRO - cheap +-.003 units they work for what i am doing. I have found to be at least to the tolerance advertised. I made very rigid mounts for them with covers.
- Motor moved- I put the motor on the outside of the machine so that it does not get covered with coolant. this was a little tricky but not too bad
- Lights- mounted cheap harbor freight Florissant light under hood and then desk lamp to side
- Other - cheap vise to cut stock with. drawer dividers from amazon and I really like the place to hand the chip brush in close reach
