Has anyone added flood cooling to a benchtop lathe?
AmericanMachinist
Mar 3, 2020
195
I have a Logqn 200 10" lathe with a chip pan and it sits on cast legs.
I don't enjoy the smell of oil smoke and i am considering how to best add flood coolant.
The lathe is indoors, so cleanliness will be key.
Has anyone done this?
What about a Mist system
I know what you mean about the smell of oil smoke , I did switch to a cheap mist system that seemed like a good solution at the time but it also came with its own drawbacks, I got tired of setting it up and removing it every time I used my lathe, the cleanup of the mess was another problem I had to deal with .
It just was not too practical to use the mister so I put is away and went back to using cutting oil again.
In my limited experience a mist system is alright if it is permanently installed to your lathe and ready to use otherwise it is more practical to just use a few drops of oil and be done with it.
My lathe, mill, & bandsaw came with a flood coolant systems but I have no idea if they even work. I don't want to run flood coolant in my home garage.
I do spray on coolant manually sometimes. One thing to note is if your lathe has felt wipers be cautious of flood coolant, you can end up with chocolate milk on the ways. My lathe came with rubber wipers & I swapped them out to felt. Didn't realize what could happen until one time when I was spraying on a lot of coolant.
Thanks. What's the concern with flood coolant? I imagine it can be messy if slung from a part, but i wasn't keen on spray mist for a similar reason, not wanting to spray fine mist on adjacent surfaces.
Messy sums it up. Can fly all over the place. If not used often it can go rancid & cause rust. I know they make anit-microbial products to help comabt that. Perhaps there are better products out today. I hear synthetic coolants are better for that. The coolant I have is sythentic & I mix it with distilled water one spray bottle amount at a time. I used flood coolant on the horizontal mill at the local college, cleaning up wet chips was not fun.
If I had a shop & used my machines daily I'd definitely run it. Sometimes I won't use my machines for weeks or at times even months. There are things that I would love to use flood coolant for but I just don't want to deal with it in my home garage. I use my garage for other things too.
I've never used a mister myself. I don't like to keep the garage door open when I'm working in there so no mister for me. I hear Fogbusters are much better than misters but again no experience with them either. They're also not that cheap & no one really makes cheaper knock offs that I'm aware of.
Another option are MQL systems like Acculube which don't seem to be talked about much here. The lubricant is usually not toxic & there are vegetable based ones. They are expensive though & is probable why many hobbyists don't have them.
After seeing acculube on you tube I tried some it is good for me if I water it down by 50% or more. No smoke and only some pleasent smell. I use it with an acid brush and it hasn't seemed to cause any corrosion, it leaves a waxy residue. In try to keep it cleaned off. What's strange is that the emulsion has unique properties which defies my experience with physics in that it evaporates at an incredible rate. Mix a batch in a container in the morning any it will be dried up by afternoon. Covered or close container is best.
my lathe has a full flood coolant system Which I have never turned on. I don't know enough to use or maintain it and when I got the machine I stupidly carried the rear splash enclosure to the recycle yard because it seems so huge. I also wonder if I could utilize the feature in a helpful way without incurring a lot of extra maintainence work for me to keep up with. I think I could control splash issues by selecting when to use it and some shop built guards. I'm interested in others experience with this.
I was wondering if soluble oil had a use in a home shop, you answered my question.
The cutting fluid I got from NAPA is soluble oil.
Wonder if there's an application for dripping something like cool mist (dripping to avoid atomization), coupled with a small pan and something like pig mat below to catch it.
I just really don't like oil smoke :)
I'm sure you could rig something up with a soda bottle and an IV tube. I just use spray bottles from the dollar store, works fine for me.
John
