- Oct 4, 2011
- 727
OK so I just started grinding my own end mill on my surface grinder using a simple fixture. Two and four flute end mill are going great and then I hit a wall. What is the trick to six flute cutters?
Here is my botched first attempt. This cutter is rough to start with so no great loss but I would like to do this with nicer cutters at some point. If I set it the same way as I do for a 4 flute the wheel will hit the other teeth. Or it looks like it would. I cut the center out with my bench grinder. There has to be a better way. Any help with set up or general end mill grinding tips would be greatly appreciated.
Jeff
Jeff
