I need to make a live center for my turret lathe. I think spring loaded would be the way to go. Are there any drawings or plans anywhere? I'm not even sure what I need to know to make one.
BenefitsLow profile design gives less overhang, greater load capacity and increased rigidity.Smaller turning radius allows higher RPM's lower bearing speeds.Needle bearings distribute stress for up to 6,800 lbs. radial load capacity, extend life 2 to 3 times that of conventional live centers and...
