- Dec 26, 2016
- 2,015
I'm in the market for a small belt grinder that doesn't take up a lot of room ,I'll be using it to shape , debure, grind metal mostly but also wood plastic,etc. .
I have a Chinese 1" x 30" belt /disk sander that I really like and use often so I think a 1" x 42" would be an upgrade but if I find a 2"x42" with a solid / powerful motor, I wouldn't complain.
So far I have seen a few disk/ belt grinders under different names (Rikon, King, Grizzley , Jet( Jet seems to be the best of the lot ) but they all have small motors with less HP, If I find a good one I don't think I'll even assemble the disk on it and just use the belt so I'd rather get just a belt grinder .
What do you all think of this Kalamazoo sander:
https://www.amazon.com/Kalamazoo-Sander-Motor-Contact-Wheel/dp/B000REJM3K/ref=sr_1_1?ie=UTF8&qid=1528420491&sr=8-1&keywords=Kalamazoo+1SM+1"+Belt+Sander
I read a lot of positive reviews on it but it only has a 1/3 HP, I'm afraid it'll bog down when I bear down on it but I can live with that if it tracks as well as some of the owners claim.
Then there's this Palmgren grinder with 1/2 HP but it is made in China so I'm not sure it is as reliable or as powerful as the 1/3 hp Kalamazoo.I have seen them under different names,Dayton is one I remember right now.
I read somewhere that a 2" belt also fits on it ,not sure if it's true though.:
https://www.globalindustrial.ca/p/t...01-belt-grinder-12hp-120240v-1-x-42-belt-size
Before anyone asks why not build one, to tell you the truth I haven't found a decent plan for a 1"x 42" grinder that I like, plus , it may be fun to build but it'll most likely cost me more to make one than what I can find on the market so for now I'm not entertaining that option.
So , of the two I linked ,which one do you like the best? or is there a better choice you think I should consider, budget is about $400 USD, I'm planning on getting a few of those Red Label ceramic belts that Mikey likes so much so it's all going to cost about $500.
If you have a personal experience with either of the two I mentioned or any other belt grinders , I'd love to hear what you have to say.
Thanks.
Thanks.
