Help with air compressor replacement motor
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
603
Hope this is the right place, if not feel free to move it where it belongs.
Kind of long story......I'm building an air compressor. I got a great deal on a new 80 gallon compressor tank. I already have a plan, using a harbor freight air compressor pump. The pump manual says it requires a 5 hp motor. Here's where the questions come in.
I know a "real" 5hp motor should be pulling around 24 amps. But, most of the motors being sold as 5hp actually come out to be about 3.5 with a max load of 5hp. those motors are considerably cheaper. I also know that many of the 5hp motors on factory compressors are rated a bit high. So my question is does the compressor pump manufacturer take that into account when specking a 5hp motor as needed? Would a "SPL" rated 5hp motor do just fine for my application?
My use will be limited, I doubt it will run more than an hour or two a week. I don't spray paint cars, or have lots of air tools. I plan to have a sand blasting cabinet soon, but it will be used rarely. Basically, I have just a hobby shop need, although it will be running my fogless mist-cooler for both lathe and mill.
So, thoughts, suggestions? And does anyone have a 5hp motor they need to get rid of?
Are you including an unloader? Seems like that would make it easier to startup with a somewhat weaker motor.
That being said, a HF pump probably will work just fine with the motors you're looking at.
John
Well, no. But the compressor would not put out the rated CFM because you would have to turn it slower. So assuming you used one of the 3 HP (''5HP'') motors, you want to use a smaller pulley on the motor and turn it at about 60% of its rated speed so you don't overload the motor.
I am powering mine with a 3 phase motor and a VFD, single phase input. That way there are no start windings, capacitors, or centrifugal switch to burn up, and as a bonus you can soft start it to reduce start load.
I found this helpful information here https://www.vivekengineers.net/details/Knowledge-Base/Compressed_Air-Rules.pdf
Top 10 Compressed Air "rules Of Thumb"
1. CFM delivery per Horse Power at 100 PSIG:
For "home owner" type of air compressors---2 to 2.5 CFM per HP
For Industrial Air-cooled 2-stage air compressors----3.5 CFM per HP
For Small Vane & Screw air compressors (25 HP or less) 4 CFM per HP
For large Piston, Screw & Centrifugal air compressors--4.5 to 5 CFM per HP
NOTE: THE MORE CFM PER HP - THE LESS ENERGY USED.
2. Air Receiver Size needed for these types of inlet control:
Modulating Control---------------0 to 1 gallon per CFM
On-Line/Off-Line-----------------3 to 4 gallons per CFM
Stop-Start/ Variable Speed-------4 to 6 gallons per CFM
NOTE: THE MORE AIR STORAGE - THE LESS ENERGY USED
3. Amperage per Horse Power:
115 Volts------- 1 phase-------- 10 amps per horse power
230 Volts------- 1 phase-------- 5 amps per horse power
208 Volts------- 3 phase-------- 3 amps per horse power
230 Volts------- 3 phase-------- 2.5 amps per horse power
460 Volts------- 3 phase-------- 1.25 amps per horse power
574 Volts------- 3 phase-------- 1 amp per horse power
NOTE: THE MORE ENERGY EFFICIENT THE MOTOR - THE LESS ENERGY IS USED.
4. Air Piping Size by CFM and Pressure Drop:
Compressor Room Header---0.25 PSIG pressure drop per 100 feet of piping
Main Line-----------------0.5 PSIG pressure drop per 100 feet of piping
Loop Line-----------------1 PSIG pressure drop per 100 feet of piping
Branch Line---------------2 PSIG pressure drop per 100 feet of piping
NOTE: THE LESS AIR PRESSURE DROP - THE LESS ENERGY USED
5. Size Compressed Air Line Filters to be twice (2x) your compressor CFM flow rate.
This will lower your pressure drop 2-3 PSIG and save an additional 1% on electrical energy costs.
Elements will last twice (2x) as long and this can save on your maintenance costs.
6. Lowering Compressor Pressure settings 2 PSIG will result in a 1% energy savings.
7. Lowering Compressor Inlet Air Temperature 10 F will result in a 2% energy savings.
8. The average energy cost to operate an air compressor is approximately $0.10 per horse power per hour.
9. Compressed Air system leaks totaling the size of a 1/4" orifice, at 100 PSIG, running 24 hours a day will waste approximately $15,000 worth of electrical energy a year.
10. Using Synthetic Compressor Lubricants can save you up to 9% of the energy cost of operating your compressor as compared to using a non-synthetic lubricant.
DEFINITIONS:
CFM= Cubic Feet per Minute - Volumetric air flow rate.
Inlet Pressure = The actual pressure at the inlet flange of the compressor.
PSIG= Pounds Per Square Inch Gauge.
AMPS=Abbreviation of the plural for Ampere, a unit of electrical current
Disclaimer: The information contained in this Article is for general information purposes only. The information given is with reference from various books & articles and while we endeavor to keep the information up to date and correct, we make no representations or warranties of any kind, express or implied, about the completeness, accuracy, reliability, suitability or availability with respect to the Article. Any reliance you place on such information is therefore strictly at your own risk.
Do you have the specs for the pump? I generally tend to go the buy once, cry once route. With a real 5hp motor you will have better performance, and if you ever find a better pump you will have the power to run it. Noticed the Baldor motors have gone up substantially since I bought mine last year. Trying to run blast cabinet with an under powered unit will be frustrating. Here is what looks to be a good deal from a good seller. Best of luck getting it all together. Cheers, Mike
Here's a WEG made in Brazil : not a bad price- shipping included
I don't know what "higher rpm" they refer to- 3440 is the higher of the two common speeds, 1725 being the other
You gonna put a condenser on it? Dryer?
Makes a huge difference.
For the immediate future, no. Or should I say not yet. I'm in the planning stage of a new shop, likely 35'x35' or so. That should happen in the next year. When that happens, the compressor will be central located and air piped around and throughout the shop. At that point I will definitely add stuff. Right now, it is going to replace my little homeowner wheeled unit.
I suppose using a 3ph motor is an option, but not one I've really considered. I have a 7.5hp idler motor on my RPC. I'm not sure that is enough for a compressor.
