Help with Ellis dividing head
craptain
Sep 21, 2017
96
I have just acquired an Ellis dividing head in remarkably good and mostly complete condition. Photos show what I have. What I don't have, or think I don't have are collets and a center. At the sellers home I decided that it used 3C collets, which I use on my 9" South Bend. However on getting back to the shop, I am not sure. The 3C almost fits, but not all the way. I have not yet done a really good clean out on the spindle, but still not sure that will be sufficient. Does anyone have any knowledge about these? Is this some variation of 3C? I also have to check out the thread on the spindle to see if I can use a chuck from my lathe.
Information seems to be scarce for these dividing heads.
Sent from my SM-G930T using Tapatalk
I have a carrol which is very similar looking to your ellis. It takes 3c collets,but I had no problem getting collet to work,you can probably get by with one 1/2" to mount an arbor for the gear cutting.
I made a threaded adaptor and mounted a 4 jaw chuck on the end. Nice that you have a tailstock. It should adjust so you can dial down the backlash.
My old dividing head looks very much like your Ellis, but has no mfg. name on it. It has a B&S #9 spindle bore.
Yes, some versions did have B&S #9 but this particular model doesn't.
I have a 3 jaw 4” Buck set-tru chuck mounted on my Ellis. And have no reason at all to have it hold collets. I could make it hold collets. I have a round holder that holds collets that can be mounted in a 3 jaw, but have not used it on the Ellis. That brass colored area on the top of your Ellis. It has two set screws. That is your black-lash adjustment. I would mount a GOOD 3 jaw on it, my 3 cents…Dave
Thanks for the response. I would like to mount a chuck for some jobs, but really I want to mount a center for use with a mandrel for gear cutting. I know that I can do it with a chuck but prefer options. Also not yet checked out the spindle thread, to know what to get. (Or make)
I knew it had a method to adjust backlash but didn't know how so that is great information. Of course I have not really played with it yet.
You can mount a center in a 3 jaw chuck. Remember, I said a set-tru chuck. I cut gears ALL the time. And when done on my Ellis. I have NEVER done it between centers. Instead, typically with a spud…Dave
Note: maximum range on a 3C collet is about 1/2”.
The chart below shows common imperial spindle nose sizes. The spindle on my dividing head that is similar to yours is 1-3/4-8 thread, which is not on the chart below. The spindle nose on your Ellis dividing head is quite likely to be one of those sizes, and a quick check with a scale will tell the tale. If a thread lines up every eighth inch, it is 8 TPI. An Ellis dividing head will not have a metric spindle nose, so checking diameter with a caliper is good enough. 2 minute job...
Well it looks like a chuck is the way to go. It's true that what I want to do can be done, and done well, with a chuck. I am just used to the precision and ease of mounting with collets. I will be at my shop later today and will (amongst other things) be taking a closer look at the dividing head.
Thanks to all for the input. I will be happy to see more.
So.... I measured the spindle nose and it's 1.75 x 8 tpi. Nothing I have, but something I can make. Eventually. Or start to search EBay.
I have a couple of flywheels from treadmills, so maybe I could knock out a backplate from one of them.
