Help With Emco Fb-2 Mill
marcthorpe
Z axis of my Emco FB-2 mill?"
Sep 9, 2016
4
can anyone help me with reparing the z axis on my Emco FB-2 mill. i lost the key way and it went downhill from there. i need the whole assembly if possible.
thanks
marc
Welcome Aboard Marc!
It looks like Emco parts are a bit hard to come by. Maybe build your own? Which parts are damaged?
You will need to get the readers some pics. You will get lots of help when we can see what's going on. Best of luck
this is the z axis crank assembly for incremental up / down adjustments. this all started when i lost the key way for the screw shaft that connects with the crank wheel. when i repaired it then i was nervous about the great effort it continued take to move the cutter up and down.
but i could do it. now nothing works. and out of frustration i did all kinds of make-shift approaches noteably a set screw instead of keyway.
also i don't remember if these vwavy washers were part of it or not. at this point i think i need the whole assembly but at least the crank handle and the hardware that stacks up above and below the bearings just below the crank handle.
i think these wavy washers are part of it but i am really not sure.
any help will be appreciated;
thanks
