@anticgov
I can't imagine the job taking more than 10 minutes per piston after the machine/machines are calibrated.
First, I am NOT volunteering to tackle this job. I do not have a good method of holding a piston, I could not hold the required tolerances, plus cross-border shipping alone would be a significant cost. However, I do have a few comments.
Going from 17mm to 19mm is not practical for honing alone. That would take months!
Honing is typically done to remove machining marks from previous operations.
I believe the steps would be:
1) setup (I'd insert a 17mm pin and uses that to align to the machine centre)
2) boring from 17mm to slightly less than 19mm; likely multiple boring passes
3) reaming to 19mm
4) final honing
Machine setup definitely takes time and will be included in the final price.
Also a commercial machine shop has many other overhead costs; land rent/mortgage, machine/equipment costs, insurance, electricity, heat/AC, salaries, consumables (tool bits, lubricants), etc.
If I had to quote the job, I'd start at a full day's work for the four pistons, call it 8 hours times the going shop rate.
Then add on another 40-50% for overhead costs.
Some of the difference is that I run a home machine shop, not a specialty engine shop.
Luckily I can work at my own pace.
I am not trying to lecture, just trying to set your time and cost expectations more realistically.
Good Luck, I hope you find a place to help you.
Brian
