The answer is no. 9" junior's used a 16 pitch gear, 9/10k's used an 18 pitch gear. Even with the bores the same, the two do not mesh well together.
If you have no gears, and the bores match, you can replace all gears. That means the common stud gear that is 16 teeth, too, as well as the screw gears.
joe
