Helpful Info On Drill chuck Tapers
HMF
Site Founder
Administrator
Sep 22, 2010
7,223
Copied from http://www.newmantools.com/tech/taper.htm
Tips for ordering drill chuck arbors:
Most often, a drill chuck arbor has a longer end that is either a straight shank or a male Morse Taper to fit into a drill press. The other, shorter end of the arbor is a male Jacobs taper to fit into a drill chuck. If a drill press has a non-removable male spindle, the taper is usually 33 Jacobs Taper.
JACOBS TAPERS
JACOBS LARGE SMALLTAPER# DIAMETER DIAMETER LENGTH--------------------------------------- 0 .25000" .22844 .43750 1 .38400 .33341 .65625 2 .55900 .48764 .875002 short .54880 .48764 .75000 3 .81100 .74610 1.21875 4 1.12400 1.03720 1.65625 5 1.41300 1.31611 1.87500 6 .67600 .62409 1.00000 33 .62401 .56051 1.00000---------------------------------------
MORSE TAPERS
LARGE SMALLMORSE DIAMETER DIAMETERTAPER# (A) (B) LENGTH--------------------------------------- 0 .36510" .25200 1-15/16 1 .47500 .36900 2-1/16 2 .70000 .57200 2-1/2 3 .93800 .77800 3-1/16 4 1.23100 1.02000 3-7/84-1/2 1.50000 1.26600 4-5/16 5 1.74800 1.47500 4-15/16 6 2.49400 2.11600 7 7 3.27000 2.75000 9-1/2---------------------------------------
BROWN & SHARP TAPERS
LARGE SMALL B+S DIAMETER DIAMETERTAPER# (A) (B) LENGTH--------------------------------------- 1 .23922" .20000 15/16 2 .29968 .25000 1-3/16 3 .37525 .31250 1-1/2 4 .40233 .35000 1-1/4 5 .52315 .45000 1-3/4 6 .59961 .50000 2-3/8 7 .72537 .60000 3 8 .89873 .75000 3-9/16 9 1.06705 .90010 4 10 1.28927 1.04465 5-11/16 11 1.53176 1.24995 6-3/4 12 1.79681 1.50010 7-1/8 13 2.07310 1.75005 7-3/4 14 2.34375 2.00000 8-1/4 15 2.61458 2.25000 8-3/4---------------------------------------
