- Feb 9, 2017
- 5,183
The next mod was one I’d been thinking on for quite a while. Lots of times I’m doing small pieces and need the blade adjusted close to measure. The 4x6 doesn’t really come with anything so i copied a piece my FIL had on his which was basically a rod into a piece of pipe with a wing screw. Easier and cheaper than hydraulic or pneumatic but no lift stop where I could just lift if after the cut and it would automatically stop where I needed it for the next cut.
I had an idea for something and made this first prototype. It worked good but didn’t have enough range. Great for thin pieces. But not right. I ran into another of my favorite thing now a 3drawer file cab for $25. It was a 30” deep model, perfect. Now I had enough height and clearance to make the lift stop long enough to cover all I might run into. I used a photography light stand I’d gotten out of a thrift store as the donor. I’ve not done any huge projects but the couple of times I’ve used it having it up on a stable platform, all my scraps right at hand and the improved lift stop my bandsaw workstation has finally come to fruition.
