HF 8 inch Drill Press - rattley noisey spindle
gorlosky
Jan 16, 2014
81
I have a HF 8 inch Drill Press and the spindle just seems to rattle a lot. I run at low speed and I have pulled the spindle out and can't see or find any issue with the bearing. The arbor shaft does seem to be out of round .005, and just don't know if that is making the rumble noise.
Are you sure it is the spindle? Or is it the motor pulley? That happens on a lot of these.
.005 is a lot out of round... Do you have any shim stock to stick in the bore to hold it still?
Bernie
Does it sound like this one?
[video=youtube_share;_aotdl-8MwQ]http://youtu.be/_aotdl-8MwQ[/video]
Let me know what you figure out because I could never figure it out. I sold it.
The one we have from Harbor is noisy. Never worried about the noise since it was sitting on a hollow table. As long as the spindle ran true I was happy. Mine is making noise from the drive belt.
Mine is also from the drive belt as I used a drill to just dirve the spindle pulley and it was quiet. I wonder if a simple idler wheel would help ?
