HF Mill Back Together Again
wayback machine
Jun 6, 2015
303
I thought some here might be interested - After buying and disassembling this thing, over a year ago, it's finally back together and running :~)
I needed a small mill for my small shop, and after trying to find a Clausing 8520 or similar for quite a while, I gave up, and so here it is.
Probably was the first one they sold, last year, after it came back in stock, and it came up, it was listed at the old $1800 price!
I bought it instantly, and I think within a couple hours, they bumped it to $2600 - But they honored the old price.
I'm not going to discuss the pros and cons of these mills, as that's been done to death - But I have a couple observations.
First - If you buy one of these, you really need to take it apart completely, and clean it, whether or not you choose to paint it, as I did.
The whole thing was unbelievably filthy inside, full of grinding grit, and just plain black grime.
Once it was back together, after being cleaned and de-burred, it's actually really nice and smooth, and surprisingly accurate - When I trammed it, the "nod" direction was within about .0005" - Don't know if just I got a good one, but it's good enough for me in any case.
What I found:
The key in the spindle bore stuck out too far to let a collet in - I wish I'd found this out when I had the head on the bench, for cleaning and painting.
After it was together, I had to turn the head to 90º, and reach in with my wife's jewelers flex shaft tool to grind it down - Annoying to say the least.
The drawbar was too long - I had to trim 1/2" off the top, in order for the lid to close with a collet in.
The amount of filler on the castings was amazing - They troweled it right over some of the joints where the head swivels and pivots.
I ground and blended a LOT, before I painted it.
The motor (2hp) seems very strong - The mill actually jerks when I hit the switch - No soft start here. It has kind of a high pitched whine, running.
Spindle bearings are pretty quiet, even with my stethoscope. I haven't checked the runout yet.
The belts shed rubber like mad - They quickly covered the mill with black dust - I think the pulleys are a little hard on them.
I changed them to Gates belts, which still shed. Finally changed to adjustable link ones, which seem OK now, and seem smoother and quieter.
And, believe it or not - The tapered gibs, on all three axes, looked to be hand scraped! But nothing else was ;~)
I have some new, old style, handwheels for it, that I still have to machine, as I'm not crazy about the disc-style ones .......
Anyway, here it is before, and after, about a year and a month after delivery, with it's new smoke gray brush paint job - It will never look this clean again.
I know red is supposed to be an auspicious color to the Chinese, but I didn't like it :~(
The stand is the top half of a Hardinge mill cabinet - I have a couple of them kicking around, so didn't feel too bad about cutting one down to size.
Very nicely done.
I've got the same one. I hate the color. Would like to take apart but no room in the shop
I agree... that looks sooooo much better. Great job with all the cleaning and painting.
Every time I see a flat grey machine I dream of painting my machines metallic orange with metallic purple contrasts and pin stripes...
sortta like I'm designing my electric flying merkel replica to look like... ebike design progress.PNG
My first mill I bought in '80 was that type. Mine was clean inside (!!) and I used it for 30 odd years before selling it. It will serve you very well!
There'll be a couple more machines going in the little shop - A Sheldon lathe, and a Vernon horizontal mill, to name 2.
Neither one will be painted gray, but, maybe not orange ........
sortta like I'm designing my electric flying merkel replica to look like... View attachment 425603
That would be cool. Go for it!
A forum member in the Airstream forum took his RV and painted it metallic orange with some blue/purple details... looks amazing.
