I've searched around and haven't found a post about this...
The gear faces on my mini lathe are not lined up. Only about 2/3 mesh between the middle gear and the gear on the end of the lead screw. I don't know for sure if it came that way, I didn't pay that close attention before I took it apart to clean and re-grease it. I could fix most of the problem by spacing out the "support plate" but I don't want to do that if somehow I don't have the lead screw installed right. It is all the way in the right pillow block and there is no play I can detect back and forth. I posted a picture that will hopefully make the situation clearer.
Any suggestions would be greatly appreciated.
Greg
Greg
