- Feb 9, 2016
- 220
(*EdiT* Thought about youtube, just watched a video, so, I'm a pro now!! Anyhows, out to go at it, any suggestions still welcome!) Seems the pinion gear shaft was frozen in my saw, got it loose, but sounds/feels rough. Took the housing set screw out, thinking I could put a grease fitting in, but, seems it may be the back side of a bushing visible in the hole? How would you remove this gear/shaft from the housing? Thinking replacing the bearings may be the ticket. Also, is it a good idea to install a grease fitting between the 2 bearings on the shaft?Any help appreciated, andyh
