[Lathe] Hitachi Seiki HT-25 with FANUC 10T
johneezreno
May 30, 2018
16
Going through a learning process with this beast. From initial start up to fighting with OT007 OVERTRAVEL codes and a EMG code that has the control locked up, at the moment. The FAPT option looks interesting. That might be interesting to learn to use.
Sent from my SM-G950U using Tapatalk
For anyone who's looked at this post, I figured it out. While turning the ball screw by hand I noticed the drive belt pulley to the motor was turning. There is a, most be safety thrust assembly that disengages pulley from screw. Luckily I had alignment Mark's. Lined the up. Pushed into place. Vualla! EMG went away because signal was met.
New problem. Can't get the spindle to start. HOLD is the code.
