My general recommendation is that for a single time install, it is a lot easier to program the VFD from the keypad vs. the computer. About 5-10 minutes vs. futzing with the software which is finicky as to system installs and the interface is pretty crude. The software is helpful if one is tweaking parameters or trying to find a programming error. If using the keyboard, the WJ200 locks out high level commands, so they need to be unlocked first, this is indicated in the attached sample parameter file for 2-3 Hp mills.
You need to be using
ProDriveNext software for the WJ200, the current inverter software version is 2.1.26.3
STEP 1: If you are installing Pro Drive Next for the first time, please download and save the “PDN drivers” folder (.zip file below). Open the PDN drivers folder and click on the appropriate driver for your 32 or 64 bit system; the file name will be named “dpinst32.exe” or “dpinst64.exe” depending on your operating system. The required driver files will be installed in your computer device.
CLICK HERE TO DOWNLOAD PDN_
http://www.hitachi-america.us/ice/sites/default/files/PDN_Drivers.zip
STEP 2 (possibly): Are you connecting with your drive via USB cable? If not, proceed to STEP 3.
In order to connect your Windows-based PC to a Hitachi inverter using the
USB-CONVERTERCABLE, a driver must first be installed on your PC. Please download the file below, and run the setup program to install the driver. IMPORTANT! DO NOT connect the cable to your computer BEFORE installing the driver! Download the file and unzip the file.
CLICK HERE TO DOWNLOAD USB-CONVERTERCABLE Driver Version 1025
http://www.hitachi-america.us/ice/sites/default/files/PL2303_Prolific_DriverInstaller_1025.zip
STEP 3: To download ProDriveNext, click on the link that follows. Select Save (do not select Open or Run) to download the software to your computer. Download ProDriveNext
http://www.hitachi-america.us/ice/sites/default/files/inv.en_PDN_Inv2.1.26.3.zip
Installation procedure for Pro Drive Next Version:
1. You should have already downloaded and saved the file PDN_Inv2.1.2_en.
2. Please
unzip or extract all the files included in that file archive. You can download a free unziping program like 7-Zip.
https://www.7-zip.org/
3. Once the files are all extracted, please find the “
Setup.exe” file inside the folder. Click on “
Setup.exe” file to install the software. If you get an error then unistall and reinstall the software. There are four separate modules that need to be loaded for the program to work.
4. Assuming you have installed the USB drivers (Step 1), you should now be able to open ProDriveNext using the newly installed icon within the Programs files in your computer, and click on "Configuration" on top of tool bar.
5. Then click on "Update Catalog" to get all the devices installed or updates from previous data files.
6. You can now begin creating new parameter and program files with the ProDriveNext projects
Make a folder Hitachi Software. Copy zip files to that folder
PDN_Drivers.zip
Right click on each file and use 7-Zip to extract files, the folders and names will be created.
PDN_Drivers
Open the folder PL2303_Prolific_DriverInstaller_1025 PL2303_and double click on Prolific_DriverInstaller_1025.ex_
Open folder PDN_Drivers and then open folder InstallImages and double click on dpinst32.exe OR dpinst64.exe depending on the operating system
Open folder(s) PDN_Inv2.1.26.3 and double click on setup.exe
