- Jun 12, 2014
- 4,808
What works is machine and individual specific. If ER32 is the most convenient then use that, at the end of the day it will not make any difference in the ability to hold an end mill in your mill. You are mostly limited by the design of the mill as to rigidity and TIR. When I had a bench mill w/o a power drawbar I used an ER-32 system because it was the easiest. An ER-32 system will hold tighter tolerances than a R-8 collet system, in particular with the less expensive collets. When I moved to a knee mill with a power drawbar, I have not touched my ER collets and primarily use a CNC chuck and a set of Lindex R-8 collets because the ER system is much less convenient. I use dedicated R-8 holders for my annular cutters and face mills. If I had a larger mill than the R-8 system becomes the limiting factor.
You do not need an extensive set of ER collets if using them with most end mills, as the shanks tend to be standard sizes, so something like a 1/8" increment set is fine. If you have an odd ball size you can use the chuck or just get a full imperial sized ER collet set. I will mention that often a metric 1 mm increment ER set is sold because it covers the full clamping range of the collet system, but the clamping range depends on the quality of the collet and the TIR can be pretty terrible at the extremes of the clamping range. I would go with an imperial set, surprised at how inexpensive they are. On the R-8 holder I prefer the nickle plated precision versions, the Shar's one that I use has a TIR ~ 0.0001" and you aren't going to get much better than that. A coated or ball bearing nuts makes tightening easier and can improve accuracy but they are not inexpensive. You need to buy a wrench for the specific nut you will be using.
22pcs/set ER32 COLLET SET Complete Sizes including all 16th & 32nds --New | eBay
22 PCS Complete Sizes ER32 COLLETS CONSISTS OF: 1/8,3/16,1/4,5/16,3/8,7/16,1/2,9/16,5/8,11/16,3/4, 5/32,7/32,9/32,11/32,13/32, 15/32,17/32,19/32, 21/32, 23/32, 25/32, 22pcs total. YOU CAN CHANGE THE COMBINATION OF THESE 22 COLLET SIZES.
www.ebay.com
R8 ER32 ER Collet Chuck Tool Holder .0001"
<!-- <ul><li>Shank: R8</li><li>Type: ER-32</li><li>Drawbar End: 7/16"-20</li><li>Runout: 0.0001"<br /></li></ul> -->
www.shars.com
