Does anyone have any thoughts on holding tiny drill bits down to .3mm (3 tenths of a mm)?
I have a couple pin vices for them and one has a spring loaded spiraling action - I push a block down against the spiral and it spins the bit. Kinda neat, but for what I use it for (circuit board work) its a pain in the butt.
I've seen collet sets for rotary tools that go down to .5mm.
Some mini chucks I've seen advertised as 0-3.5mm or so actually bottom out around .8mm.
I'd like to work with the rotary tool up front - it has a 1/8" standard collet. There is a smaller collet in the set, not sure of the gripping diameter, but all the tool shanks are 1/8 that I use. I think a hand-held cordless drill may be too heavy of a tool for the real light board work, but if I can grip the bit holder in a normal chuck that may come in handy for something at some point. For the fine work the rotary tool I would think would be more ideal, though. Even a "drill press" frame for better control would be nice. The tiny bits are quite delicate.
