- Aug 13, 2016
- 16
By far the hardest part of this build was cutting the rack and pinion gears with a fly cutter in the lathe.
I added slide out base extensions if a little more leverage is needed on the arm and interchangeable dies for the end of the rack. An arched brass shim behind the rack and a shim in front keeps back lash to a minimum.
